johnheath said:I've found this preamp schematic and wonder where you would place a "volume knob" if you were to rack it up? A dual gang pot I suppose?
johnheath said:We were experimenting a bit with gain control and attenuation and ended up with a dual gang stepped pot in front of the first gain stage. As discussed here maybe not the dest way.
Fixing with the feedback resistors has also been in my head and perhaps changing and adding some values?
How ever it won't make it very quiet
EmRR said:A stepped pot is definitely better than a continuous type.
Feedback control won't HURT noise, so long as layout is clean and short. You should be able to implement that with the same noise result at the same gain.
johnheath said:Thank you Doug
Interesting and very informative.
Well fact is that I built one of these a couple of years ago together with my son...
Anyhow the measurements were very fine and likewise the sound that was very transparent and clear... sounds great for acoustic guitar I can say.
mjrippe said:Doug is a great resource, isn't he
I would say that if you built one with the attenuator after the transformer and it worked well and sounded good then keep it that way!
There is one advantage to this design - it is impossible to overload the input stage because you basically have a variable pad in front of it.
mjrippe said:Careful there - a stepped SWITCH is better than a continuous pot. A stepped (detented, so you feel clicks as it turns) pot is a piece of crap that is of limited use. Because pots are low precision (10% or worse), the detents on one pot will not likely match those on another. Cartec used them and I think Thermionic Culture did too. Your left and right will never be the same level at the same number of clicks. Sure, use them for your mono device that you want to recall settings on, but then when you build a second one it will not match.
The only exception is a single center detent on linear pots, of course.
Best regards
// John
ruffrecords said:As I mentioned earlier, this type of circuit does not lend itself to wide ranging gain changes by manipulating the negative feedback because of stability problems. You might be able to change it safely by 10dB or so but not much more.
EmRR said:True....I don't consider those to be stepped pots anyway, but most people don't get that difference.
