Well, you could also replace the triodes with NJFET's. I used a pair of 2n3819 into a 5k center-tapped xfmr. Then I got back to my senses and used a VCA. 8)joaquins said:Also I don't see the point to avoid SS stages in a world that is SS... It's nice a tube gain stage, but to avoid OP TX you could use a SS output to get low Z... same for input and you could use a more easy to get IP TX and work at lower Z...
abbey road d enfer said:Well, you could also replace the triodes with NJFET's. I used a pair of 2n3819 into a 5k center-tapped xfmr. Then I got back to my senses and used a VCA. 8)joaquins said:Also I don't see the point to avoid SS stages in a world that is SS... It's nice a tube gain stage, but to avoid OP TX you could use a SS output to get low Z... same for input and you could use a more easy to get IP TX and work at lower Z...
joaquins said:abbey road d enfer said:Well, you could also replace the triodes with NJFET's. I used a pair of 2n3819 into a 5k center-tapped xfmr. Then I got back to my senses and used a VCA. 8)joaquins said:Also I don't see the point to avoid SS stages in a world that is SS... It's nice a tube gain stage, but to avoid OP TX you could use a SS output to get low Z... same for input and you could use a more easy to get IP TX and work at lower Z...
.....Bear was trying to avoid IP tx ..."
JS
Considering it takes the AC plate voltage to provide the rectified DC, I think it's close to unity. The AC plate voltage is not very high, in regard to the low-ish gain of the circuit, and the side-chain DC voltage needs be about 20-30V.Big Bear said:Could someone give me details of the side chain transformer that is used a lot? Is it just a lowZ 1:1?
Quirky design IMO.In Analog's (I think) design http://www.twin-x.com/groupdiy/albums/userpics/Mooo.JPG
I don't really understand your question. The xfmr is there to provide push-pull operation AND impedance adaptation. The fact that it also provides galvanic isolation is a welcome bonus.is the transformer simply a phase splitter or is it serving as extra isolation too maybe?
Yes, you would need one, because there is no other usable output for the audio signal, unless you want to redesign the ouput stage for plate resistors and managing the interface with the outside world differently.I guess my question is, would I still need one if I were to take a balanced signal to the side chain? And if so, why?
In an era where valves were considered expensive, it could be justified... by bean-counters. Why designers accepted playing this game is somewhat beyond me, except they may have found gratification in squeezing as much functionality as they could from as little hardware they were allowed to put in their products.Big Bear said:The majority of vari-mu circuits I have built have been very similar to the Altec 436C. http://www.dvq.com/hifi/images/436c.pdf Which simply AC couples taps from the output valve anodes and rectifies this.
In view of the common availability of high-voltage FET's, it makes sense.Is it reasonable to take a balanced signal from the output valves anodes (similar to the 436C) and buffer this to a lowZ line, then rectify this and process through side chain circuitry to the GR valve grids?
It's not easier, it's probably not as good, it's more expensive, I wouldn't do that.Or maybe it is far easier to tap one anode and buffer, then transformer balance, then rectify..?
Yes, it's one of a very few non-VCA based feed-forward limiters.The TAB U73 is an interesting circuit, it has a dual output from the IP transformer which is amplified and by a PCF80 with a cathode follower, then transformer balanced.
There are so many ways to skin a cat that I cannot say that I would "approve" a side-chain. The subject has been debated here, you want the SC circuit to deliver a low impedance to the Atk/Rel path without loading too much the audio path, choose the one you feel comfortable with.I would like to have an agreeable and approved side chain circuit that works well, initially I did not want to have another transformer added, but if a cheap one works that is OK. alternatively if SS circuitry works then that is great too!
PRR already answered that. It takes a high-voltage differential amp; it's not impossible, just complicated.DaveP said:Wouldn't a differential amp like a long tailed pair work instead of an interstage? Very high input Z equals small coupling caps. Presumably the thump would cancel as its common mode?
Great thread BTW 8)
best
This is not the issue. The difficult part is getting rid of the common-mode voltage; it takes a differential amp capable of handling about 100V variation of CM voltage. Not trivial.DaveP said:Yes he did, but it could be a low voltage Vari-mu stage as well and cathode followers can follow very large voltage changes.
Here, we're talking about both grids driven by anti-phase signals coming from the transconductance cell, exactly how it's drawn.DaveP said:
Not entirely. If CM voltage varies, quiescent current varies also.The voltage between grid and cathode is constant no matter what, it follows anything.
That would be in a perfect case of infinite resistance constant current source, which a resistor to ground is not. You could increase the CM rejection by increasing the value of the common cath resistor Rt and tying it to a negative voltage, or even a true CCS. In brief, using standard valve oscilloscope technology.If the varimu tubes drop any voltage together it makes no odds as its the difference that's amplified.
No. CM input Z is very high (as in a Fender amp), but differential input Z is just the grid resistors, no bootstrap there.The input caps are tiny due to the very high input Z, so charge/discharge quickly
Bootstrap works when the cathode moves in the same direction as the grid. In the diff amp, the grids move in opposite directions hence the cathode doesn't move.DaveP said:So the antiphase cancels the bootstrap then?
That wouldn't solve any problem. The recovery time is directly dependant on the LF corner frequency; whether it's 0.1uF in 200k grid leaks or 2nF in the 10Meg bootstrapped Z of a cath-follower, the effects are the same.Two bootstrapped Cathode Followers preceeding that stage would help then?
