abbey road d enfer said:
..... My comment was pertinent to the A52.
Thrue Phantom is definitely constant-voltage, .....
Hmmm.... sorry, but I am unable to spot a constant voltage (source) [seen at the microphone] as there are - referring to the schematic posted above - these two 6k8 resistors which transform every voltage into a current.... even when the supply voltage is variable it stays a (variable) current source - at least this is what I have learned in school....
And the "inventors" don't claim anything different:
[quote author=True Phantom ®]
Another approach to supplying 48-volt phantom powering is to utilize a voltage-controlled
current
source in series with 6K8 resistors. In Figure 1, the 48 volt power supply is now replaced by two 48-volt regulated
current sources.
[/quote]
BTW, the maximum current (shortcut) though a 6k8 resistor at 48V is ~ 7,1 mA, at 62V it is 9,1 mA. Therefore the maximum current variation can only be 25 %.
Now let's have a look at the claims for the A52:
[quote author=AKG]
..... the A-52 provides the following outstanding features:
• Safely and effectively accommodates dc-supply inputs ranging from +7 .5 volts minimum to +60 volts maximum.
• Automatically adjusts itself to power a 12-volt microphone only with any dc input from +7 .5 to just below +50 volts .
• Automatically adjusts itself to power a 12-volt or 48-volt microphone with any dc input from +50 to +60 volts.
• Acts as a regulator with any dc input above +13 volts; the dc source itself need not be inherently well regulated.
• Provides additional filtering; the dc source may have some what higher ripple than a passive-divider network permits.
• Works with microphone-input transformers having untapped and center-tapped (but floating) primaries.
[/quote]
and:
[quote author=AKG]
A52 guarantees in addition, due to its high A.C. resistance (approx 2. megaohm), a hum or unbalance damping of 100dB.
This damping is sometimes required, since a potential difference may occur between the preamplifier (by way of the microphone stand) and the ground point, should the microphone not be properly setup. This could - provided the source impedance is low - on the one hand superpose on the D.C. supply voltage of the phantom and, on the other, made weaker by way of the balanced attenuation, take its effect directly at the amplifier input.
[/quote]
And this was my statement concerning the A52:
I don't know why, but I am unable to see anything remarkable new compared to the current-source-design A52 from AKG from the late 60's:
So where are the
remarkable properties of the "true" phantom ® (of the opera) which makes it superior over the A52?
An "improvement of 0,0056% distortion" or "0.06 dB higher output" ?
Come on....
The Ri of the current source is the same as of the A52:
The major benefit of this design (= True Phantom ®) is that the load of the emitter followers is now not 6810 Ω in parallel with 1000 Ω (mic preamp input impedance), but 2.00681 MΩ in parallel with 1000 Ω. (
the Ri of the current source is 2MΩ) Per Equation 1, the load impedance as “seen”by condense microphone emitter follower is now 999.5 ohms.
[/quote]
So......
