Most loudspeakers have >1% THD. Should this discourage attempts to reduce distortion of amplifiers or sources?kingkorg said:Now, having in mind 30$ Schoeps based mics like mxl603 have stock 0.1% thd at some serious SPL, and can be biased further to 0.02% thd. SO WHAT ARE THEY TALKING ABOUT HERE!?!?
Capsule's physical thd is larger than that.
If the amplifier distortion is already below 0,001 % - as in this case - I would say: yes.abbey road d enfer said:Most loudspeakers have >1% THD. Should this discourage attempts to reduce distortion of amplifiers or sources?
Joost Kist said:Dear fellow recording engeniers,
Because I am the designer of the True Phantom®, ...... The distortion of the microphone is consequently lower:
at 100 mVRMS standard: 0,00095% = -100,4 dB true: 0,00058% = -104,7 dB
at 200 mVRMS 0,0039% = - 88,1 dB 0,0024% = - 92,3 dB
at 300 mVRMS 0,016% = - 75,5 dB 0,0104 % = - 79,6 dB
RuudNL said:But isn't a price of £478.80 a bit high for a distortion reduction of 0.0001%?
(You can measure it, but would you be able to hear it?)
So, you consider that improving absolute performance, regardless of context, is a useless task?analogguru said:If the amplifier distortion is already below 0,001 % - as in this case - I would say: yes.
For me it is the same as the "need"/desire to drive with such a car. Of course some do, do you ?:abbey road d enfer said:So, you consider that improving absolute performance, regardless of context, is a useless task?
This example is about both performance and bling. I understand the performance aspect, although I agree it's futile considering the context. I don't care about bling.analogguru said:For me it is the same as the "need"/desire to drive with such a car. Of course some do, do you ?:
I must say this figure comes out of thin air, but I don't think it makes sense selling them for pennies. There is simply not enough market for it.$10? Seriously?
Sure. that's why I wrote earlier "if someone wants to kill brain cells about improving the last 0.001% of performance, it's OK with me;"Though they solve different perhaps non-existent "problems" they do take a look at things we may take for granted.
