SonsOfThunder
Yep, okay, be sure when you check those wires that you are set on AC volts! Blues and black will be the +/- 15V, the whites are for the phantom.
HTH!
HTH!
Hi, i'm a newb also, but ... don't know if you should get 'continuity' through the trafo. primary and secondary windings are separate, so if you're checking in to out... hmm...what I did was just a simple continuity check. (the beeping signal?), to see if the out was connected to the in on the trafo. I got no beep at all, This would indicate a broken winding inside correct?
I have 120v going in via the red and black wires, but i do NOT have 15v at the blue and black. Same for the phantom, 120v in, and 0v at the 2 white wires.
SonsOfThunder wrote:
I find it very strange that both trafos are dead. Are you sure you measured AC volts?
I
HTH!
Charlie
