Well, i'm going blind from opamps. (4x) 2*5*2*0BC + (6x) 1731. checking work on 2*5*2*0 BC 'visual inspection'. Haven't seen a close enough pic of someone's built BC board to be sure of a few things.
Fabio or anyone, could you say yes or no to these:
**Insulated wire goes from hole left of V- graphic (the one with white ring) to hole left of Q2
**Q4/Q5 = 1 x 80 or 82K resistor
**Did you all connect C5 above or below the PCB?
There are a few empty holes on these 2*5*2*0BC opamps:
**just below the printed 'C1'. On path between C1 (1000p) and C5. Don't see anything on schem that goes there...
**Also empty hole to the right of R9... to the right of the white ring, trace from R9 to V+. R9 should go right to V+ on schem so looks okay.
**GND pin to pre board is in, but hole next to it not connected. I see no ground on schem, only V+, V-, and O
Correct?
Related note: Gus suggested 'try TIP29 etc.' assume he meant for input pair, was thinking of doing another board or 2 with these... should i change anything in the layout to accomodate TIP29s, or slap em in there?
