Rob Flinn
The switches will operate the relays without the leds connected up. The switches are 2 pole & one of the poles operates the relay & the other pole turns the led on.
For the OEP A262A3E RL = 27k and RC & CC should not be fitted as they are not needed.
So CD1 and CD2 mounted on pre-board take care of this. I wondered why those were on both the opamp parts and pre parts lists. Tracing the tracks i see what you're saying.the GND on the opamp board is used for 100n caps between +v gnd and -v gnd.
I'm fitting mine under the board.
Cool... gotta figure a case/ shield for these still. Anybody know a source for correct size little black boxes... jewelry etc.?I think the empty GND hole was for the shielding...
Also, I don't think a relay is involved with the PP, just the PAD, POL, LINE, and HIZ.
