G
Guest
Guest
anyone?
* is it possible to have an output level switch in the preamp? im wondering if overdriving it a bit can bring a nice effect, and controling the amount of overdrive would be better controled with a output level.
here are some pix of my current state:
www.o-zen.com/saffi/api
* for the relays i used Axicom FP2 D3012 (24v) http://relays.tycoelectronics.com/datasheets/fp2.pdf
are they worthy or am i better off using switches instead?
* on the melcor and 2520BC, instead of the BD139 i used BD441
http://www.ortodoxism.ro/datasheets2/0/01glh2g3agku3e7l7q75q2rt41py.pdf
is that ok?
I have tested, it sounds good. Also, using good caps, the unbalanced out sounds good too. Some different stuff going on in low end, not time to compare them a lot til now. Both are ok.* will the servo output level be the same as the line out? im thinking of making a switch between them (SW_IRON ), has anyone tested the servo out, and can say how it sounds?
* I'm planning to make a small hatch for each opamp that you can open and change the opamp from melcor to 2520bc at will. i understand there is an issue with the c5 cap. right now i put 220pf, which i read is better for the melcor. will it work ok on the 2520bc aswell? or shoudl i just add another cap on the melcor to balance it (C5=120 + another 100pf on the melcor)
*what are the leds in the PSU for? are the mainly acting as diodes, or do they have some calibrating usage? im wondering if i should mount any of them on the chasis...
* was the melcor's oscillation fixed in the end of the proccess of trying to fix it? there is so much technical talk i have lost track of what parts are the problematic ones.
