Hi everybody
I've finished 6 API312 channels and I haven't this problem .. maybye i'm very lucky lol. about the 48V mod, I tried the mod with a 10k resistor between switch and led so as to discharge CCP1 through the LED and it works fine. It would works better with a 5k resistor I think, making the led glowing higher and discharging the cap faster. actually the 48V is gone after 10 / 15 seconds, which is OK for me.
But I have another problem.
The first time I ran the first channel of the API, I got a short circuit between 48V and ground wire, which made the negative Led (from the PSU) glowing less and less and then I saw smokes coming out from the DOA !
I changed the DOA, changed all electrolyics caps on the 312 board, changed the +48V regulator, C1 and C2 of the PSU and I checked the negative current regulator, all boards and soldering.
Now the problem is when I run the preamp, the R2 resistor ( the 10ohm, 5W) comes very very warm (I can't touch it with my fingers , 10 seconds after running !) , and when I stop the current, the negative LED ( from PSU), stop glowing instantaneously, while the positive LED stop glowing after 20/25 seconds.
I have tested with another board and the problem disapear, which means that the problem is certainly on the 312board which had the burned DOA
Does somebody have any idea of what to change on the board? ( I already changed eletrolytics caps and DOA)
thank a lot for your help, 'cos I become crazy with this preamp ! lol
