Phazinhead
Hello
I discovered somthing strange.
To check the noise I used to plug a headphone into the API output. The API output is a monophonic balanced one, but the headphone plug is a unbalanced stereo. I was trying to record the noise, and what a surprise when I saw on the vu-metre of Sound forge that noise at maximal gain was only around -70dB (at 0dB input gain on Firepod preamp).
I used both balanced and unbalanced cable, and the result was the same !
I got only some "click" when switching pad or phase, but no big buzz or hum !
You can hear the result and tell me if you think noise level is correct or not ( first you'll hear the channel one, in line input, then in mic input, turning the pot from minimal gain to the max, and the same for the second channel, which is the closest to the PSU board)
http://krokro1.free.fr/channel%201and%202-%20Line%20and%20Mic.wav
But the strange thing is when I have the headphone plugged into the first channel and a cable plugged between the second channel and the Firepod input, I've got no hum and buzz at all !!! but if I remove the cable between the API and the firepod, hum and buzz are back ! So, I can't record this hum ( because it disappear when I connect the API on the firepod). Do you think it is normal or not ?
I don't know what to think now.. I feel a bit stupid to haven't hear the noise through the API sooner ... lol
