bobschwenkler
The N version is non-shorting. You don't want that as when you switch gain levels more of the negative feedback may be routed to ground and the gain of the opamp may jump momentarily. You need a shorting switch.
jrmintz said:I could be wrong, but isn't the input transformer on a 312 1:8?
Dsaudio said:Hi from Argentina, one pic of my DIY 312 , diy 2520 , diy output transformer and Jensen input.
very quiet( no hiss or hum) 18 Vrms of output.
khstudio said:Dsaudio said:Hi from Argentina, one pic of my DIY 312 , diy 2520 , diy output transformer and Jensen input.
That's cool!
I was going to try the same thing... building the 2520 circuit right on the pre card.
Any chance you could post & share the files - for etching & component placement???
Also, what version & schematic did you use for the 2520 circuit?
Kevin
Dsaudio said:Sorry for my english
For the output i used grain oriented silicon ST audio output transformer ( 10 hz to 200khz) with 1:2 -1:4 turn ratio, mine are one primary and 2 secondary
supports +26 dBu @ 50hz without distortion.
you have linx audio transformers in BRAZIL.
http://www.audiolink.com.br/audiolink/transformadores.htm
You don't need a special transformer for api 312 output, try with any output trans , with a regular 5k 600 ohm trans inverted works fine with lots of headroom.
Some people uses power transformers instead audio transformers with good results.
Greetings from Argentina
