Potato Cakes
I'll get you voltages tomorrow. When I did pull them I was getting continuity between 2 of the legs on the 140s and 139s that went bad.
Paul
Paul
steves.mastering said:Hi, I’m just working on a pair of app992’s.
A generous diy’er on here sent me them free with another PCB I bought so I don’t know how old they are.
Just about to install the mounting pins, I see on post 7 that the PCB will be mounted solder side up, but on post 30 the PCB is mounted component side up.
Is this the difference between version 1 and 2? In which case, my PCB’s don’t say v2, so should I just assume I have the first version and I should mount them solder side up?
Ste
baslotto said:Hi guys,
Does anybody know where I can buy a few DIY kits for APP992s that I can run in 2 channels of TheDon 250EQs using 16V rails?
My goal would be to enrich the low-mids harmonics, would they be good for that?
Thank you for any tips! I’m in California btw.
Stefano
ppa said:Hi Brian,
many thanks for your comments, I really appreciated them.
BTW is possible to upgrade the APP992 ver 1 to ver 2.1.
best regards
Pier Paolo
Falk said:Hi there,
does anyone have the built documents for the app992? I received the kits but do not have any assembly instruction. Could someone help me out?
Thank you,
Falk
