sr1200
Had a weird idea, not sure if it would work properly or what I really should use to do this, but here goes.
If i took say 8 T-pad (600ohm) attenuators and racked them with in/outs, would that be sufficient to run the output of a preamp (say an API or Neve or Tube Pre etc.) through the attenuator, then into the converter?
I've recently run into instances where I would like to drive some of my pres abit, but the resulting output volume is too much for the converter to handle without being pinned flat 0.
Is there a better solution to this?
