Nicely done. I like the creamy off white paint which gives it a certain "Je ne sais quoi" modern/old scool charm.
I am curious whether the drivers could be mounted inside the cabinets, with hidden hardware, and whether the speakers allow for that sort of mounting alternative? Is there an audible or aesthetic advantage to mounting them on the outside? (NOT being critical ... just curious as I contemplate a similar build for a pair of 4 inch speakers for my ham radio transceiver. )
Thanks. Nice job. James
Hi James.
Aesthetics aside, if you mount the drivers to the rear of the baffle it will change the cab's internal volume somewhat, and probably interfere a bit with internal reflections (by positioning the rear of the magnet closer to the rear panel).
If you're determined to rear mount, it would pay to radius the forward edge of the speaker cutout with a roundover bit. That should quell unwanted edge reflections.
Why not use a rabbeting bit fitted with a guide bearing to mill a shallow recess, to flush-mount the driver?
I'm using ¾" MDF for the baffle for this reason.
Other things noted:
There's no mechanically sound reason to join the panels with dowels, or to add the four ¾x¾ glueblocks shown in Dave's clone. Pointless extra step.
Using small (lamello-type) biscuits is better than dowelling the butt joints. Alternately, just glue/pin with a 1½" finish nailer/clamp up.
I have done exactly so to build larger two-way reference monitors - all I did differently was to mill the rear cab edges and removable back panel for a rabbeted flush joint.
That's not needed for horrortones.
Pre-rout the rabbeted recess for the speaker in the baffle after cutting out the hole (easiest if done before cutting the baffle to size), likewise make your hole for rear panel connector cup if using one - glue/shoot/clamp.
It's an idiot-simple tiny box.
