stockrock said:Vintage LO1166 transformers fit into the single space 500 format just fine. I keep reading that they will not, but they do. Trimming the fiberboard a bit is all it takes. Doesn't need any kind of mod to anything other than that. Accurate repros probably should fit too, but it is said again and again a compromise is necessary on repros to make them fit. But if the real vintage LO1166s fit...
Just curious , what lams you did use.Spencerleehorton said:Second batch done now, only 7 left!
Are these still in production?Hi team, does anyone know if there's a difference between the LO 1166 and the LO 1166 /A...... I can see its been wired in parallel winding configuration both on the primary and secondary..... thanks
Will look into a 1U version, don’t know if there is a thinner bobbin which could hold the lams, will report back.
