BA283AV - oops!
jrmintz
NY
Hi All,
In a moment of stupidity I fired up my imitation 1290s with the BA283 cards in backwards. It's not hard to do (for me anyway). Am I likely to have toasted anything? I can't tell from the schematics and they work, but the distortion is too high.
Thanks :sad: :oops:
I think my cards are OK. The problem I have is a 60-cycle hum, I guess from a ground loop somewhere. Here is the schematic I've been using:
http://www.jlmaudio.com/Schematic.htm
Click on 'JLM module and BA283'. What I'm wondering is, is it safe to lift one end of the 12 ohm/1 watt resistor or the 270 ohm resistor? Any other ideas?
Hi Peter,
Joe Malone figured it out - I never would have gotten it. I used an 18-0-18 transformer without realizing it and Joe said that would let the hum through the regulator. Gotta get a 24-0-24.
:guinness: :sam: :guinness: :sam:
You need atleast 3-4V differens between in and output to get good regulation! I did the same mistake with my first 1290 unit!
