micaddict said:... especially on bare feet.
What?
Better conductor than wire
If you have both hands busy then still you have two free legs
ln76d said:No, i didn't need to change any electronic parts after removing inner mesh.
Never was sounding worse.
To be honest, i don't want to describe difference due to poor translation and i have no "flow" in that type of descriptions.
Audiophiles have best poetry for subjective feelings related with audio equipment
Only difference which you should notice is in high-mid and high frequency area. It doesn't affect low end response.
Check by yourself. Don't screw headbasket, grab microphone (don't touch circuit) for a metal base or body pipe, with other hand grab headbasket. Make voice test and gently take off headbasket. If you will get hum, try to ground yourself to the preamp case (with a wire or bare feet ). You need to place PSU far away from the microphone.
If you will hear difference between mesh and no mesh at all - with one mesh your final sound should be somewhere in the middle. Don't touch circuit!!!
ln76d said:With the body pipe attached. I didn't edit text well, first version was without pipe, but you don't need fully opened microphone to test it Anyway if you want some fun, it's ca. 100V. Nothing pleasant.
Foam at the saddle, that shell you made, can affect low end response.
That's why i didn't recommend to mount it. That amount of any material can affect any frequency range depending on it acoustic properities.
Ok i'll try - internal mesh, especially painted and cheap, usual make coloration (rather unpleasant) in mentioned before frequency range. You shouldn't notice any change in amount of specific frequency range but rather cleaner, more natural response.
ln76d said:To be honest - i don't know.
I never used such material inside microphones.
It may affect.
Am using flat surface thin stripes which works very well.
Main purpose is to damp some internl resonances, or headbasket ringing but definately not affect frequency response.
That's why for me mr jollo mods are little bit...
ahh...
I can't say what
mtl777diy said:I just asked Michael Joly and he said the foam at the base of my modded Oktava MK319 serves to isolate the capsule mount from the PCB assembly and thus reduce physical handling noise. It is also used to create a conical base diffuser to reduce internal standing wave coloration. The material is an open cell foam covered with hot glue.
ln76d said:mtl777diy said:I just asked Michael Joly and he said the foam at the base of my modded Oktava MK319 serves to isolate the capsule mount from the PCB assembly and thus reduce physical handling noise. It is also used to create a conical base diffuser to reduce internal standing wave coloration. The material is an open cell foam covered with hot glue.
This guy isn't serious...
I would throw out that foam, before its degradation, guys were talking about taht in this topic.
