You would absolutely need to have these matched.That is discouraging for the thought of stereo patterns with CK12 capsules.
I'd love to try that but I'm not sure I understand your advice clearlyTry a 500pF at > than your B+voltage from plate to ground with your capsule before changing it
Something a bit like this ... circled in Red. ?A very crude (1st order) low-pass filter - a capacitor rated at least as high as the B+
" connected between the tube plate (aka anode) and ground."
M
For clarity, I've always understood this to be a high-pass filter, thus it channels unwanted highs to the grid where the reversed phase interaction removes them from the signal path. Originally, it was intended to reduce RFI problems in mics, but it does also have a touch or audible impact at the very high end of the audio spectrum. Because of this, some folks now refer it as a "tone capacitor". You're likely to have to go larger than 500pF before it starts to have much impact on the character of your mic's sound.A very crude (1st order) low-pass filter - a capacitor rated at least as high as the B+ high-voltage supply used to power the tube, connected between the tube plate (aka anode) and ground.
No, Khron is right AFAIK. This is a low-pass filter IMO. Excessive heighs (and everything above) are dumped into ground. Yeah, its a kind of tone cap.For clarity, I've always understood this to be a high-pass filter, thus it channels unwanted highs to the grid where the reversed phase interaction removes them from the signal path.
I agree, it is always a good idea to attenuate amplifiers at the top end that are so far upstream in the signal chain, otherwise unwanted radio reception...Originally, it was intended to reduce RFI problems in mics, but it does also have a touch or audible impact at the very high end of the audio spectrum. Because of this, some folks now refer it as a "tone capacitor"
+1You're likely to have to go larger than 500pF before it starts to have much impact on the character of your mic's sound.
