BBC Transformers
G
Guest
Guest
Bought the following model from Canford for a pittance (£3.50) - BTW check out their second hand/shop soiled offers (as well as their clearance offers) - B- gauge patchbay for £25!!!!
Back to the problem...
So I now have a 1 1/2 inch tall "open coil" transformer (bigger than I thought) with the following characterstics
LL228 2PE
Impedence Ratio 2:1
Primary Inductance 5
Winding Resistance Primary 7 ohms
Winding Resistance Secondary 3.5 ohms
What can I use it for (apart for a paper weight?)
600:300 line level (if it really is a 2:1 impedance ratio) or 600:150 (if you really meant to say "turns ratio").
You want details on how I came to that conclusion, or did you just want the answer?
[quote author="NewYorkDave"]600:300 line level (if it really is a 2:1 impedance ratio) or 600:150 (if you really meant to say "turns ratio").
You want details on how I came to that conclusion, or did you just want the answer?[/quote]
originally just the answer - but now I am intrigued
Yes, 5H or greater.
Inductive reactance is 2pi(fL). So at the lowest frequency of interest
6.28(20 * 5) = 628 ohms.
UK said a 2:1 impedance ratio, which would indicate a 600:300 transformer. But if what he really meant is a 2:1 turns ratio, then it's a 600:150 transformer.
Lastly, the physical size and the lack of shielding indicates a line level transformer.
[quote author="NewYorkDave"]Yes, 5H or greater.
Lastly, the physical size and the lack of shielding indicates a line level transformer.[/quote]
All I am doing is quoting from the catalogue
Here is the pdf
http://www.canford.co.uk/commerce/resources/catdetails/2743.pdf
In the picture it's the middle on in the second row...
I am awaiting more info from canford
