I will do the Lavry blue compare test against Beis. When I listened Blue I wasn't that impressed like AD24QS impresed me. But I didn't listened both together Now I have some more tests so that will be possible. Also I'm still in the comunication with mr Beis and it seems that he is working on the digi sync option for AD24QS.
Here's the latest letter from him...
every now and than I continue to think about the wordclock issue. Currently I have an idea that I want to persue the next days. But that's complicated, code for a complex FPGA has to be written, tested and the hardware has to be built at least for a test.
With the help of a DAC an external synchronization might be possible, too: The DAC's Rx has MClk, LRClk an BClk outputs these signals should easily be usable as master signals for an ADC with the ADC's Tx and ADC-IC in the slave mode (currently the ADC-IC is in master mode). All other settings like M1, M2 must be set correct manually.
It wouldn't be a wordclock, but a synchronization by an other digital audio signal. Maybe that helps.
Should my idea of external synchronization work satisfactory I might continue to follow my old plan of a multichannel ADC (i.e., probably 8 channels, expandable) with ext. sync capability and possibly a MADI output.
It is, BTW, not really difficult to build an synchronizable clock when you simply use a wide-range VCO like you can find in other devices. But all discussions about low-jitter sources become ridiculous when such an RC-based oscillator is used. This is why I aim at a VCXO (voltage controlled crystal oscillator).
Best regards and a happy New Year
Uwe
