A lot of powered stage monitors use the Neutrik powercon ,
when glasses of beer go flying its definately a safer bet than an IEC .
Does it have rounded corners?3D printed frame is a nice solution.
I went on and ordered a custom die for the exact same IEC inlet without a fuse.
It’s for a 22.5*30.5mm hole. If anybody needs it:
https://sl.aliexpress.ru/p?key=KVc8Z9L
Edit. This is for the back side mounted inlet. I haven’t received the punch yet, so can’t comment on the quality.
Probably not. Should have standard corners.Does it have rounded corners?
I think it has square corners, but it's correct for the IEC/fuse combo.Probably not. Should have standard corners.
Does the one that @gyraf got have round corners?
If it has square corners, it is better to mount the socket from outside.Probably not. Should have standard corners.
There’s an extra plastic front panel on top of the inlet and there’s no room for outside mounting.If it has square corners, it is better to mount the socket from outside.
Do you have a link or picture?There’s an extra plastic front panel on top of the inlet and there’s no room for outside mounting.
OK, I get it. You think the opening in the plastic panel is large enough, or you'll need to enlarge it?View attachment 113227
This is the same synth from the other thread.
I want to replace the inlet with a modern 3-pole one. It does fit, but if it’s mounted at the back of the panel. A plastic outer panel has approximately 2mm of internal height clearance and can’t fit the inlet if it’s front mounted.
I went to see Guns n Roses at Slane castle in 1992 ,
Axl arrived in his own private chopper around 45 minutes after the show was due to begin ,
An hour late and he still hadnt made an appearance , the crowd flew into a rage , started filling empty cider flaggons with piss and slinging them up on to the stage , Lord Mountcharles arrived out told the crowd if the missbehaviour didnt stop the show would be canceled . Roadies had to be sent out to clear the stage of debris , there was piss everywhere . My guess is their backline smelled funny for quite a while after .
