thermionic
- Joined
- Jun 3, 2004
- Messages
- 1,671
Let's say you're passively summing the O/P from 3 op-amps via low-ish value resistors (the op-amps are happy to drive low loads, so you're using something around 1k or less). The op-amps need a cap to block their DC offset. Traditionally I would put the caps right at the O/P of the op-amp, with each feeding the summing resistor (op-amp - cap - resistor).
Let's say, for whatever reason, you were to put the summing resistor directly at the O/P of the op-amp, with the cap afterwards - therefore making your 'summing node' the output of each cap (op-amp - resistor - cap).
What would be the implications for performance if you implemented this method?
Thanks in advance.
Justin
Thanks in advance.
Justin
