I'll try to follow along....piece by piece as I can since we are alone here
![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
we should be able to figure it out within all of the guides and videos although there are differences I'd guess.......
the unit is warmed up first???
so there is .775vac at the + and -pins of your input xlr inside to make sure there isn't an impedance loss?
http://library.hairballaudio.com/images/fetrack/input_test_points.jpg
are you setting your qbias resistor to o or to wide open????? are you testing it to make sure????
one thing too that seems to be noted is the importance of the tant caps at c19 and 20..........?? I forgot what brand/type you used here.....guessing low esr?? maybe swapping those places wouldn't be a bad idea......
are you following the older version calibration on the Hairball site???? Seems the Hairball method is slightly different than the mnats video version...... doesn't really talk about the meter until that next step in the calibration......just the voltage drop.....??
