i guess you found the problem.
- none of the light yellow points reach ground. i guess bad solder point at the ratio board.
- wiper has continuity to main pcb as well as the ccw leg, but they also have continuity to each other (e.g. when i check ccw against wiper or 15 against 17...) bridge?
