Ah - so the VU Lamp can run off the AC Secondary? I thought I'd be tapping into the power supply's rectified/regulated +30V. Thanks for clearing that up!
Just posted in the Rev D thread as well with a few 2-1176 Q's...
Thanks for your excellent help, Mike! ;D
Edit/Add: If you are going to update the Rev A BOM / Mouser Cart - I have a few other suggestions that might help others:
1) Include the washers or nuts needed to offset the "0 Set" pot off the front panel, and the washer/nut for the Input Pot (so the knobs are as flush to the panel as possible). I had these laying around - but lots of noob's certainly won't...
2) Consider using slightly longer screws for the PCB Rail Mounts. The included screws don't even screw all the way through the nuts (they work fine, but I could see them stripping out with a heavy hand)
3) Pre-Drill the PCB Rails for the optional Stereo Link Kit, and provide Stand-Offs, Screws, the "Link" switch and 1/4" TRS link jack with the Stereo Link Kit.
4) Consider a secondary "Premium Cart" with the Bourns output Pots already subbed for the standard Alpha pots in the regular Cart link.
I'd also add a link on your website to the quick Wiring Diagram picture you e-mailed me (looks like it was done in Paint).
Just a few things I ended up doing "after the fact" that might make this "that much easier" for a complete noob
