Echo North
I think you're on the right track. Keep GR off and get the signal passing through the signal and line amp correctly. Tripple check all of your wire connections.
Volume11 said:I know this is going to sound stupid but, which fet exactly does the qbias adjust the voltage to?
w!ll said:Ok, continuity test suggests they are. How would that happen and how can I solve that?
w!ll said:That's with the input wires to the transformer removed.
3nity said:hey Mike.
is that a dual op-amp preamp you got on your avatar....ala jensen twin.??
more pics?
Merci.
