Rob Flinn
I don't know where you guys are getting your 2N3707's from, but out of a total of 40 I had 24 above 250, 12 between 200-250, & only 4 below 200(all 4 were close to 200).
0dbfs said:I've got a complete BOM that I will post once I go back through and check a couple items.
I have seen it mentioned that electro's should be rated close to operating voltage instead of over-rated. Does this matter? Ie; using a 100V electro in a position that will not exceed 35V (better to use an electro rated closer to 35 + a couple)?
Thx,
Jonathan
[EDIT]
Here is a BOM I put together to help myself understand all of the components:
http://diy.dbfsforge.com/mnats_d1176/mnats_1176_revA_BOM_DUAL_jonathan-burtner.xls
I referred both to the schematics, the boards, and various other threads.
Please be sure to check that these components are adequate for your particular needs before ordering.
Shoot me an email or PM if you find there is anything worth changing and I will update the list with a new version.
jonathan
