Hallo
I'm just finishing my first 1176 build, Mnats Rev D board and the full Hairball bundle with a Blackface enclosure, just looks awesome! Soon ready for passing audio through the unit and starting calibration so these are exciting times!
However, after reading more about input transformers ( http://www.groupdiy.com/index.php?topic=10611.0 ) I just could not resist buying the UTC O-12, found one on ebay and though it might get me a little closer to the original sound. At the same time I bought a UTC A-20 as well.
Being the audionerd that I am I now want to, of course, have both transformers in the unit. So my idea is to install a switch so i can change the input between the O-12 and A-20. More options = happy audionerd!
I've built the unit now with the Altran input transformer ( which I'm sure is just excellent ) and plan on getting the thing up and running first, then make the modification when everything else is working. My question is if someone else has tried anything like this before? Is it as simple as I imagine by just adding a DPDT switch after the T-Pad attenuator? Will the calibration be off when switching to the other input transformer?
Any views on this subject would be most appreciated. I also want to say thanks to Mnats and Hairball Audio for their excellent work.
/Edward.
