pittsburgh
Right, but what I'm saying is that I don't have a 5M pot anywhere.
pittsburgh said:What points should I be wiring the 0 adjust pot to?
Quote from: canidoit on July 02, 2009, 04:02:30 pm
Whats the calibration procedure for the distortion trimmer? I was turning the R86 trimmer and I am not sure what the normal setting for this is?
It's the preamp linearity setting. Usually setting it approximately midway will be sufficient, however if you want to set it correctly them you will need to invest in some equipment (at least an oscilloscope, signal generator and THD measuring setup). Apply a 500Hz -30dBu signal to the input, set the input to fully CW and the output to about 2 o'clock and measure the THD of the output. Tweak R16 for minimum THD.
TheWolfman said:However when attempting the next step and adjusting the meter in GR mode with the null adjust I can only get the meter to move maybe from-21 to -20 at the most using the front panel adjust and the "Null Adjust" Trim.This is using the shorting jumper.
I suspected that I may have a faulty Trimmer for R75 Null adjust so I switched it out for another (this time a 5k as thats all I could get quickly,but I figured this would suffice) but still to no vail.Reading the voltage across R74 it reads a constant value of 2.65V which is then not affected by any adjustments made to R75 Null Adjust.
