TijuanaKez
- Joined
- Jul 19, 2011
- Messages
- 51
I have a unbalanced valve preamp that I like to use to dirty things up a bit. Problem is, by the time it's had a chance to dirty, the output level is crazy hot. I've been chaining through the 1176 with the input knob way down which works a treat sound wise but how careful do I need to be to not damage the input tranny?The input attenuator comes before the input tranny so I would expect this to be ok but I'm no expert.
Also, I have some unbalanced synths and distortion pedals etc that I'd like to treat audio with but a lot of the time they will eventually need be connected to the balanced input of the pultec or the 1176 etc. Set up in the patch bay, I've been connecting to the balanced input with an unbalanced cable which means 'hot' is connected and 'cold' is grounded as well as shield. This also results in half the level so I'm needing to pump a lot more into the 'hot' side to see a decent level on the eg. 1176. Regardless of noise, is this 'ok' or am I going to hurt the input tranny's on my gear doing this?
