Click to enlarge
As
mentioned previously, I have had some transformer boards made up for this project.
These will fit the Altran O-12 clone that will soon be offered by Ed. Ed will be providing boards with each input transformer.
They will also fit the following transformers:
CMMI-2PCA - Cinemag's version of the O-12
CMLI-15/15B[PC] - as used in some of the UA reissues
Lundahl LL1540 - for a G1176-style input but wired 2:1 stepdown
OEP A262A2C - wired reversed for 2:1 stepdown
Other transformers that use a standard pinout could also possibly be adapted to use this board.
The Lundahl and OEP will work with the board as-is. The Altran and Cinemags require wire links configured to adapt to each unique pin assignment. Pads are just under the transformer footprint and a guide is printed on the screen layer of the board. You can use short pieces of tinned bare wire under the board or insulated wire through the holes.
There are footprints for constructing an H-pad
described by W O'B and used on some of the UA reissues. Use this option if you are not using a T-Pad.
Self-etch files have been posted on
my Rev D page.
I will also post information on how to get just the board soon.
