As Ed mentioned earlier I have been working on an input transformer PCB. Since most of the modern input transformer options seem to be PCB mount I wanted to provide a tidy way of nailing them down without resorting to vero/perf board. The boards will accept the following transformers:
Altran C-3837-1 - O-12 clone
CMMI-2PCA - Cinemag's substitute for the O-12
CMLI-15/15B[PC] - as used in some of the reissues
Lundahl LL1540 - for a G1176 style input but wired 2:1 stepdown
OEP A262A2C - wired reversed for 2:1 stepdown
There is an option on the boards for an H-Pad as used on some of the reissues described by W O'B and neatly drawn by ed. This might provide a low-cost alternative for those unable to get a T attenuator.
Of course, you can also use a T attenuator at the input or use a potentiometer following the transformer ala G1176.
I'll post the files for a home etch, but will also have a batch made that can be distributed with the Altran transformers that ed is going to offer.
