vineyardgray
- Joined
- Jun 12, 2008
- Messages
- 123
Well, I've got my first build done and mercifully everything appears to sorta operate the way it should. I have yet to do a proper calibration, but I'd say I'm in the ballpark.
A couple questions persist which I'd like your help to allay.
1. Selecting different ratios via the ratio switch does not appear to reduce the amount of gain reduction being applied. This is using a 1kHz 0dBU sine wave. Is this right? I was assuming that, for instance, if 20:1 reduced the gain by X dB, then 12:1 should reduce the db by Y - a lower amount. This is not the case on my unit - all ratios finally settle on the same gain reduction amount for a given input value.
2. This question has more to do with test gear loading - I'm using a NTI minirator as my source. 0dBU gives me a .781 Volts value on my DMM. As soon as I plug it in, testing that same unit on the backside of the panel mounted XLR gives me .5XX Volts. Am i witnessing input transformer/circuit load or is some other phenom at work (i.e. ***** signal generaor?)
Thanks to all - this site is a wealth.
MR
MR
