Troubleshooting diary Part 3:
Main issues: attack pot not working, o/p pot scratchy 6-0 area only when O/p is present (balanced)
- Fixed: O/p transformer red and blue where inverted (damn habit of calling pin 2 "hot" in some countries, red being hot, blue being cold
Now it's all good, but changed nothing
- Reworked the O/p pot. Tested the value, doublechecked cable for continuity from pot to the next component and is ok. Pot Still scratchy from "6" to "0"
Question: I've noticed the O/p pot measures only 120k across when wired to the Ratio board ????????? is this normal?
- Pot only scratchy when an o/p load present. Unplugging the plug and it's fine. Outside world cables are fine and the unit is a modern UFX or ADI8DS (only ones I have here ATM)
SUCCESS! I forgot to ground the board! Clean as a whistle now!!!!! Little hookup wire from C25 negative side to the O/p transformer chassis (which conducts to the chassis)
When I get home going to start from the beginning again - voltages and what not.
If I could have some help with the attack pot would be great
- With a scope and a sine, should I only see half a wave? should I only see DC? What am I looking for here?
- Voltages across the board when unit on for a while - 90% of them spot on, some of them 0.03-0.1 volts difference, worst case scenario a 1v variation from MNATS "schematic + typical voltages"
- Spoke with mata_haze, which suggested me to look for cold joints and test continuity, specially around the ratio board area/pot hookups.
- Checked all the pots for values. All ok
- reworked ALL the connections from the pots, replaced resistors and caps (as per above post)
- Double checked all values for Ratio Board resistors as per hairball guideline. All OK. reflowed solder points
- Checked continuity for attack pot (from FDH333 to pot, from pot to release and pot to ratio board), all OK.
- Same with Release, but here something caught my eye, not sure if normal: I can get continuity between the lug that should reach QBias wiper and ground????? (regardless which way you twist the trim pot)
- REading this post, already at page 36
The unit is compressing, sounds amazing , but stuck at a rather useless attack setting for most sources
