sage
could i t be that your attack pot is wired in reverse?
zekester said:Echo North said:zekester said:Echo North said:zekester said:Just figured my issue to be as mentioned earlier in the thread, funky power transformer. It seems to be sensitive to a little movement. I read through and found a few people with issues with these, is there a high failure rate on the avel lindbergs?
Shouldn't be. Maybe 3% at the most.
I put in an order for a new one, so that should get me back up and running again. Hopefully, I'll be in the 97% on this one![]()
If the new one works fine (confirming the first one you got was bad), let me know and I'll refund your second order.
Will do. I appreciate it.
RichardM said:Hi Again,
I just can't seem to get any change from moving the q bias trim pot. I have tested some of the voltages and the 30v at the side of r79 tests exactly as it should but many of the others I think are too high. G at q11 = -1.8 vdc D at Q11=18.3 vdc and S at Q11= -2.3 vdc. I am really unsure what to do because I thought that the voltages in this region would not read as they should until the unit is calibrated properly. The o adjust trimmer that is accessed in the front works as it should and I am sure that I am following the calibration steps properly. Do you have any suggestions? My only other concern at the moment is that the output knob raises the level as it should when being turned up but as it nears the max, it makes a bit of a clunk and enters a hiss zone. Maybe this has to do with the calibration, but I am unsure. Thanks for all your help!
Rich
sr1200 said:ossilation?
