There is a fair amount of this in the original units. you think you are above the mild fuzz you can pull from them on stuff like bass?I did all of the calibrations in the videos on mnats site, i've yet to do the distortion adjustment (this could be the culprit?) but, what seems to be happening is, I'm hearing some distortion of the signal when compression is occuring, but I only seem to hear it when I have the attack and release settings at their fastest speed (fully clockwise) Either if both are fast or even if just the release is fast and attack medium, but it's really apparent when both are set to fastest. It also seems to get worse/more apparent when the ratio is increased.
Dvaughn said:"Extremely short release times may even introduce harmonic distortion if the gain reduction changes between cycles"
mitsos said:(btw, the meters on the Purples don't do this, they sit at zero.)
Idiophonic said:Hello to everyone on the forum, long-time lurker here! Apologies in advance for the long post.
I recently completed a REV D build and everything went smoothly, I just want to thank Mnats and Hairball for making this as straight-forward as it was.
I do have an issue I'd like to get some feedback on: After calibrating, and then double checking my calibration, the threshold on my compressor seems to be lower than on both original and UA 1176 re-issues.
When running a 0 VU tone into a UREI, UA, and my Hairball, the Hairball goes into GR with my input knob around 48, IOW, the input is almost turned down all the way. The UA is closer to 9 o'clock, the UREI around 10 or 11 o'clock.
I measured the total amount of gain available in my unit. With GR switched off and the input and output dimed, I have approx. 44 dB of gain through the unit, which I understand to be normal. (40 db was my understanding.)
The result is I am unable to turn down far enough to get light amounts of GR on a particularly hot signal. The sound of the unit is comparable to the other units otherwise, just my input knob must be nearly all the way down to match the behavior of the other units.
I have checked and re-checked the Q-bias adjustment. I thought I may have been sending the unit the wrong level of tone during this step, but I cannot find anything I am misreading. I don't understand why the exact level of tone and position of the input knob during this step would not have an effect on where the threshold ends up, but that is what is stated in the Mnats Q-bias video.
I am also suffering from a scratchy input pot, which I did not expect from a sealed Bourns pot. But this is less of a concern than the threshold issue.
Again, I am happy with the sound of the unit, but I am hoping to fix these last two little bugs. Does anyone out there have a similar experience or a suggestion? How can I increase the threshold to get more room to work the input knob? Any suggestions on the scratchy input?
Thanks to all of you for contributing your knowledge to this board and LONG LIVE DIY!
hmm, did not know that purple used an IC meter circuit. Anyway, I've never seen meters do what mine do, it's very weird, and even weirder that it doesn't do it at my house! I think my bud's using it on a mix today, I hope to pass by there in a few hours and do some tests and post back.Echo North said:mitsos said:(btw, the meters on the Purples don't do this, they sit at zero.)
The Purple is a completely different meter circuit. Modern and IC based.
The MNATs versions (A and D) use the original discrete circuit.
Let us know what you find!
Mike
mitsos said:hmm, did not know that purple used an IC meter circuit. Anyway, I've never seen meters do what mine do, it's very weird, and even weirder that it doesn't do it at my house! I think my bud's using it on a mix today, I hope to pass by there in a few hours and do some tests and post back.Echo North said:mitsos said:(btw, the meters on the Purples don't do this, they sit at zero.)
Mike
I haven't looked at their schemo in ages, I was always under the impression they copied the Rev C/D schems to the letter. Not that the meter circuit should make a difference in sound, but...Echo North said:mitsos said:hmm, did not know that purple used an IC meter circuit. Anyway, I've never seen meters do what mine do, it's very weird, and even weirder that it doesn't do it at my house! I think my bud's using it on a mix today, I hope to pass by there in a few hours and do some tests and post back.Echo North said:mitsos said:(btw, the meters on the Purples don't do this, they sit at zero.)
Mike
You're right it doesn't use the IC circuit. I thought it did but it doesn't according to the posted schematic. It just has a IC buffer.
My bad.
Echo North said:The threshold is set by S4(b). You can see in the schematic it feeds a negative voltage to that point between R52/R53. One of two things might be happening. This voltage may be too negative, or the signal coming from S4(a) might be too weak.
I'd check all the resistors on the ratio board and you transistor voltages in the GR control amp.
Also what is your Qbias voltage?
The input section of the 1176 is sensitive to any noise in the pot. It doesn't take much to get some noise there. A new t-pad would probably fix that. Email me about that.
Mike
