Thanks for the warning. I took cover, but nothing happened. I checked a few voltages and everything looks fine.
The first to calibration steps where no problem and worked perfectly.
I put R44 back in the circuit and switched off the attack knob. Ratio 20:1 meter to +4.
With the 1 kHz signal I adjusted the output so that the meter shows 0.
After switching the attack knob back on... nothing happens. In fact lowering the input lowers the Vu needle - same as output control...
I guess I screwed up. If I am correct, increasing the Input should push the signal into the threshold and cause a larger gain reduction on the VU.
Already searched my **s of in the web to get clues. I'm frustrated.
