Just like the problems I had, I see there are other people who have some trouble measuring the hFE of the 2N3707/8 transistors or finding information about the best way to do these measurements. I don't know if this is the best way (I hope it is at least correct), but since in the end it was rather easy, I would like to show what I have done.
I also have a DMM that is supposed to be able to measure hFE. However, after trying all possible directions and pin combinations, the only measurement result that I could get was something around 1000. As we know from the specs the max. hFE for the 2N3708 is somewhere around 600, so that these results were obviously rubbish. I searched the interweb for some other measurement methods and in the end I came up with this setup:
The little test rig is this (constructed with some scrap material):
A DMM is attached to the two pins on the small pcb and set to mA. This will give me the collector current Ic.
The transistor to be measured is inserted in the appropriate holes of the 10 pin connector.
By measuring the voltage across the 47K base resistor, I know the base current Ib.
Finally: hFE = Ic/Ib
With this test rig I got reasonable hFE values around 290. I measured 10 transistors and they were all very close to each other.
I noticed that the measurement is very temperature-sensitive. Before writing down the mA value I waited 1 min for each transistor to heat up. After that time the value was much more stable.
My rev D 1176 is now finished. The voltages at the transistors were correct right away and the calibrations were a piece of cake. Now I'm doing some sound testing and so far it is great. Thanks Hairball Audio and Mako for the great kit!
Hope this helps someone else along the way to his 1176. Please correct me if I got something wrong.
Cheers, Mattia
Cheers, Mattia
