JW said:I know the output transistor runs hot, but how hot is too hot? I have a top hat heat sink on it but it's still very hot. About a second is how long I can grab it.
That leads me to my next question. I have the mnats power supply with the 317/337's. Is this enough to power two REV D's?
I'll probably need to heat sink these to the chassis or something.
Which leads me to my next question. Does this look like the right substance? http://www.ebay.com/itm/20g-Tube-Syringe-Silver-Thermal-Paste-High-Performance-Heatsink-Compound-CPU-GPU-/131753508718?hash=item1ead1eff6e:g:rtIAAOSwCQZZIgqt
Also, I'm not hitting on something at mouser at the moment that has these little miscellaneous parts like the little rubber thing that isolates the screw from the to220 chip. Or the little pad that goes on the back. Does someone have a link to the little miscellanious stuff?
By the way, the Ed Anderson transformer (with class A out) is really amazing sounding. I got a chance over a few years actually to go from these G1176 boards with a chip input and an OEP out to eventually a 600 ohm T pad/Altran input transformer with a cinemag CMOQ output (REV F pretty much, less output gain at 1:2), to eventually just deciding to breadboard the class A output and go full REV D. So, now it's gonna be a stereo REV D. Just sounded right to me. Still would like to hear the REV F with the Ed Anderson for the A/B output.
Neko Neko said:And the guts 8)
JW said:Okay,
I think maybe I spoke too soon on the heat issue. I left it on for a few hours and the output transistors are about as hot to the touch as a preamp tube or something. So, not really that bad and they don't seem to be getting much hotter with time.
Here's a couple pics of my dual unit. I'll probably just put some normal heat sinks on the regulators.
Spencerleehorton said:is there no longer any support for this?
Spencerleehorton said:I’ve managed to sort it now, changed both the 6.8uf tants as they must have been damaged now have working unit.
Waiting on some 200pf mica caps to change as I’ve used 2 100pf in parallel but this is just so it looks a bit neater.
Can’t get -10db drop yet but I’m sure I can tweak a bit more and find out what’s wrong.
Now I have Rev A and Rev D from you and 3 x g1176, will probably mod the g1176 to Rev D now as I’ve come up with a mod to try and g1176 to my mind has much lower output.
Spencerleehorton said:The strange thing is I know it’s not setup right as either side of R74 it’s meant to be at least 10v.
Whatever I do I can’t get 10v here and the meter to sit correctly.
Spencerleehorton said:Yes, it’s weird because I can setup the unit to get -10db with compression on both Vu and GR mode but this involves adjusting the q-bias in a way where it is not +1 dB drop.
If I follow normal setup procedure qbias is good, then setting R74 to 0v is good but I’m left with a Vu meter which is way off?
Can only get about -3db drop on GR but get -10db drop on Vu mode?
