I've verified the power supply: I have 30v at R87.
Voltages do NOT match, namely Q2 and Q3. However, I anticipated that these require some degree of calibration - which has not been executed.
It's a bear to monitor, but I did confirm that the DC voltage on center pin of trimmer moves. It moves from -1.139v noted on one leg, up to 0vdc as measured on the other as the trimmer screw is turned.
My meter is a salvage deal, and does not have any label, though it wouldn't surprise me if it didn't have diodes. Frankly, in situ, I'll leave it in GR mode anyways (which appears to function, as-is) so I'm likely just to leave it be for now
