Hi, I'm building mine with the pushbuttons and the 25k Lin Attack pot with SPDT switch! wired as Mike said in his specs... 22 to the center lug, the CCW to the Black on Ratio board and the other to the Green on the Ratio board also.
THe Q Bias Adj and the Null (R75) trim calibration, I did perfectly and my 1176 accept all that regulations at it should be! but after that, when I put back the jumper to get R44 on the circuit again, my meter drops to the left, and I can't regulate anything after... the tracking trimmer, I Adjust and the meter just rise a little bit just before the trimmer ends... I move the input and out put knobs and they do the same, rise and fall the output level, that's it, when it's supposed in GR mode when I start rising the input and reaching the Threshold point, start to see the compression on the meter and on the output...
When I hit the ratio board, I see the sine wave just reducing a little bit as it should be, from 4:1 to 20:1, and when I hit all the buttons the VU's indicator rise to the hard right, and this is right! because I'm putting the fet in a "bad biasing way! and this happens in my others 1176 and on the original too... I'll post some photos tomorrow! maybe this helps a lot!
Ahn.. one thing I notice is that in the MC76 schematic all the 3707 are changed by the 2N5088... but I have the 5088 only from Q7 to Q10... I'll try to swap all the 3707 with the 5088 and see what happens!
Eddie :-\
Eddie :-\
