crisotop
I haven't had a look for the correct value, but waht about a 500R in series with your 1k pot?
regards,
christoph
regards,
christoph
luis said:I´ve had the same problem but i actually fit by putting some more pressure in the Pot against the hole. But sanding the extra pannel in the purusha case may be the sollution.
carnitas said:sorry if i am getting off topic a little here, but i thought i'd post the wiring diagram i used to get my dual rev. d functional. i used all the parts that are now conveniently located at Hairball audio. It proved very useful for me while i was wiring the thing up. As Skylar graciously posted his diagram for the vers. 1 board, i thought i'd post mine (vers. 2 board) as it has the updated wiring info for the OT and rotary switch and meter boards. I lifted Skylar's grounding scheme for the layout (my unit is terrifically quiet!).
Also, in regards to the polarity of the OT wiring, my unit is wired with the blue on cold (-) and red on hot (+) and i'm not having any oscillation problems. Matta_Haze, is your unit working at 100% now that you switched your wiring around? it makes me wonder if i'm missing something.....
BTW, this was my first build. Took a while. lots of screw ups. lots of reading. totally worth it.
luis said:You need at least 1K, 2K will work without any problem.
What tools did you use to cut those out perfectly.fazeka said:luis said:I´ve had the same problem but i actually fit by putting some more pressure in the Pot against the hole. But sanding the extra pannel in the purusha case may be the sollution.
No good. I put more pressure and still not enough threads on the bushing to get the nuts started.
So I just opened up the panel to allow the pots to sit right up against the faceplate.
Should do the trick.
Are you saying that pin 7 is the tip(hot) of the connector in a TS socket for stereo link? Is pin 7 send or return? Where is send and return for the stereo link though? Where do you get the shield or S part of the socket, do you just grab the ground from the case?penguin said:J and D are same for stereo linking (pin 7, on both = .22uf / 3.9Mohm connection)
sorry if i was asking too much... i am pretty new here...
Hint: if you turn it in the other direction, does it drop?tman said:Hey all;
Got my rev d up and running. I've got one issue that I can't seem to find an answer to.
Upon trying to do the Q-bias calibration, if i turn R59 CW, the meter only rises, and I cannot get a 1db drop. I've scoured all sources online, but I can't find any mention of this. If anyone can point my in some direction I'd greatly appreciate it.
Tony
I had the same problem. I think you have like a tollerance range where you can be off by so and so. I was able to get 910ohm. Heres the link.Dean Roddey said:I did a search and only saw one person mention this and no one answered...
R12 calls for a 920ohm, right? It was previously I guess a 1.8K. Anybody have a source for one of those? Neither Mouser nor Digikey seems to have these in stock, though I could just not be searching correctly. Would a 1K really affect things particularly much if a 920 wasn't readily available?
271-910-RC – Xicon $0.13 US 500v 0.25w 1%
