blackwaterstudios
Member
Ok - figured it out. I have some of the strangest things happen to me!! Sounding great - Moving on to the 3rd one!
guitarwill said:hey question guys, i was calibrating my rev d and got to the tracking adjust stage in GR Mode and all of a sudden it just stops compressing.
now it's not showing compression in +4 mode and GR mode the needle wont move from all the way left. also having to crank the input and output to get to 0 in +4. The only way i can get compression and gain back to normal is to go all buttons in, but still nothing is moving in GR mode.
any advice, think i need a new ratio board?
Echo North said:guitarwill said:hey question guys, i was calibrating my rev d and got to the tracking adjust stage in GR Mode and all of a sudden it just stops compressing.
Are you sure your Q-Bias is set right?
Sounds like maybe your Q-Bias is off. If you switch GR off (short pad 22 to ground) does your output go up?
Stagefright13 said:adrenalin1982 did you follow Mnats wiring scheme and grounding tutorial? You shouldn't have any hum. It should be very quiet.
John
jordan s said:I recently made a Mouser order using the Hairball cart and C1 (Wima, 1uF, 100v, 5%) was out of stock so I substituted a Wima 1uF, 63v, 10% cap. I am going to be ok using this or do I need to order the the original cap which is now in stock?
jordan s said:(Wima, 1uF, 100v, 5%) was out of stock so I substituted a Wima 1uF, 63v, 10% cap. I am going to be ok using this or do I need to order the the original cap which is now in stock?
