Just about to build another 1176 this time a dual so using Mnats PCB for Meter and Ratio boards allong with Hairballs stereo kit and Dan's Stereo FET case which looks really cool BTW..
A few differences and just want to be sure so I am about to ask some novice type questions.
1) Hairball Meter 8027
http://hairballaudio.com/shop/product_info.php?cPath=25&products_id=59
Uses 2 LED's 5.6 to 7.6V for illumination. Can I hookup like mono versions here taking voltages straight from toroidal via 2W resistor. An what resistance range is optimal?
2) Also I am assuming the larger connectors on the back of the meter are for meter connections and smaller ones are for the illumination am I right??
3) The rotary switches for Mnats Ratio and Meter PCB's I am assuming as long as they are correctly fitting the PCB all is ok and there is no specifying hole for say pin 1. I see no indicator on PCB to align like an Op Amp would for example.
4) I will be using a fender amp style jewel illumination amp for power on indicator with 6.3V lamp. How is best to illuminate this?
This one....
http://cgi.ebay.com.au/Pilot-Lamp-Holder-Suit-Fender-Mesa-Gibson-Peavey-Amps-/370490315643?pt=AU_Amplifiers&hash=item5642f1937b
Any help would be much grateful.
