Hello All,
First I want to Thank you for this great forum and all the contributors!!
Second, I have an issue you may help me fix. I just finished building a Hairball kit audio using the BOM and mnats rev 2.2 board. My PCB is labeled "v2.2 26.01.09". the board shown in the "v2 building" document on mnats Rev D page is dated 30.04.08.
Since i knew in advance about the famous R32 burning out, I checked and double checked the Output Transformer wiring were correct and belonged to rev 2 board + diagrams.... I turned on the compressor and the R32 GONE in 10 Seconds! very strange...... since I use rev 2 and all color match the wiring guides from, MNATS it, it is pretty straight forward but yet.... R32 is burned...
I triple-read this forum but it mainly references to incorrect OT wiring from rev 1 to rev 2.... nothing else. which is NOT my case.
I took out white/red wire and measure +30V DC between that wire and the ground (violet wire) so no wonder the 39ohm resistor burns..... any idea?
I looks like the Hairball output transformer came damaged? is there any way to test it? what else could i check?
I added a few pictures to show wiring.
Thanks a lot to all of you!!!
God Bless
Ludwing
