Have you corrected R12 as per D Kulka's finding?
What are you getting on the + side of C4 and at R13?
Could it be a bad solder joint at R17 (you did say that on one side of R17 you get the full 30V, right?)?
I would look at R17 again. From what you say, it sounds like something screwy may be happening there. Unless it's something downstream, but maybe reflow the solder joints at R17. You did say you tested it and it measured correct, though.
Have you tried lifting the other leg of R17 and measure the voltage there? Basically 30V in and ? on the other lifted leg.
Mixmaster-Nate said:I can get the same WIMA component but with a 10% tolerance, will this make much difference to the operation considering it's in the pre-amp section??
canidoit said:Anyone know if there is the distortion adjustment video or tutorial out for this unit yet?
Hyder said:Hello, First time poster so I hope I am doing this correct. I am Building a REV D and the BOM calls for a .022/100/5 Wima film cap located on the attack pot (C27).
Well Mouser sent me a.022/250/10 Wima Polypropylene Film Cap instead.
Is this a problem? All the pics. I see it looks like a ceramic cap or something.
Chuck
