Any metal enclosure should be fine. No need for plastic stand-offs, but if you have them handy - why not. Make sure you connect your enclosure to the safety earth, and if connect the signal ground of your circuit to chassis in a single point. You can take the ground output of your PSU and connect it to chassis, this should be fine in most cases.any advices on putting the whole assembly in a case wich houses synth moduels (eurorack) in terms of isolation and safety?
The simplest way is just to take a parallel feed from the transformer output and connect it to the headphone amp. Given that the input impedance of the headphone amp is 10k or something like that, it should not affect the performance in any way.can you receomend the most simple way of adding a headphones out to the 1073 post EQ?
Ok so screwing a ground point to chasis, find ground point on preamp pcb, connect it to that chasis ground point, my psu is just a piwerbank to a DC plug, so taking the negativ of that also tomthe chasis ground point? Sorry i am bad with grounding logic.Any metal enclosure should be fine. No need for plastic stand-offs, but if you have them handy - why not. Make sure you connect your enclosure to the safety earth, and if connect the signal ground of your circuit to chassis in a single point. You can take the ground output of your PSU and connect it to chassis, this should be fine in most cases.
Everything that is listed "in stock" on the site is available. Payment is via crypto only, shipping is via regular mail.Are these kits still available, and if so, what transformers can be used with the 12413 kits? Thanks.
Thanks! Is the input a 15k:15k and the output a 600:600?Everything that is listed "in stock" on the site is available. Payment is via crypto only, shipping is via regular mail.
For 12413 we use Cinemags, but you can use any output transformer of your choice (as it's mounted off-board).
Yes, that's correct.Thanks! Is the input a 15k:15k and the output a 600:600?
