There is no polarity sign / square at the 24v dc point middle of the pcb. Only the double line.As I wrote earlier, you need to connect your +24V DC supply to the "24V DC" connector in the middle of the board. Observe the polarity - positive lead should go to the square pad.
In case your PSU is too noisy and you see HF spikes in the output spectrum of the preamp, you can make an LC filter, or better yet use a common mode choke instead of a simple inductor, and make a CLC (where L is a common mode choke) PI filter and connect it right after your PSU.
Let's not get ahead of ourselves though and have the preamp working first.
i dont wanna burn it, so how to tell polarity?
i left the 2 switches (impedance/invert i think) pcb off now and connected ends of wire 8+9 for testing wich i suppose is correct
