The PC mount 2623-4's would be very close after some standoffs are used under the board. The vertical 2503's will never make it. I would suggest just mounting the iron off the board and flat. I would do this will all 4 transformers and use 2623-1's instead of 2623-4's. Then...no problem with everything fitting.0dbfs said:Question:
Can I fit 2 ACA-OBO's into 1RU for four bus masters sort of like a 7800 form factor?
Thx,
J
jsteiger said:So, a DIY, all modular, vintage API style mixer. This is so do-able, and ultimately my goal.
rrs said:Hi Jeff
I am wanting to build a 14:2 channel mixer in which all channels can pan either Hard Left, Center or Hard Right.
Can I use these boards to do this and how would it be done.
Correct you are funkmuffin. Blue dot = pin #1.funkmuffin said:Hi Jeff -- I'm building my 2-aca-bo, and need to get the 2623-4's oriented correctly. Is the blue dot on the transformer pin #1? I'm assuming so, but it's easier to ask then to de-solder.
jsteiger said:Desoldering can be mighty enjoyable with the right tools ;D Don't underestimate it!
No, it is -2dB. You could adjust if this is the only stage you are gonna use.rhythminmind said:Is the output of the ACA line level?
Yes you can do this. Besides more DOA and x-fo goodness in the path, they are there to buffer the pgm mix fader and insert point. If you don't use these things, you could skip the booster section.It seems I can just take the ACA transformer output into an A/D, or do I need the booster?
