You are gonna have to trace signal thru the entire chain and see where the level drops off. Start my measuring the AC level at the output of your interface then after the 1st stage, then after the 2nd stage etc etc.
The audio signal flows between Drain and Source. The only pin you would ground would be the Gate.madbeavis said:Hello all,
I am having an issue that I cant seem to pin down with the talkback/mute circuit on the BO side. On power up I can pass audio for about 30 seconds after which the mute becomes engaged. I can short the G and S pins of the J111 and it will start passing audio for another 30 seconds before repeating the same behavior.
I initially thought it was some charge from the FB or coupling capacitors but I was not able to measure any with a meter. I do have the mute pins grounded to the PSU ground mult, not sure if that makes a difference here.
I am using the J111-D26Z as described in the build docs:
https://www.mouser.com/ProductDetail/ON-Semiconductor-Fairchild/J111-D26Z?qs=sGAEpiMZZMv4z0HnGdrLjlAuB7fe22XlO1Ow%2Fw%252BxqNuNTjpCCHmXxw%3D%3D
Any ideas on what the cause could be?
Chris
Gate goes to the header. Signal flows thru source to drain (or drain to source).madbeavis said:Thanks for the response Jeff,
The Pins I referred to as grounded are the 2 Mute KK header pins. The J111 is soldered in place on the PCB, matching the orientation on the layout mask. If I momentarily short the Source and Gate pins using a probe then signal will pass again.
Chris
The only way I can think of is there's enough DC on the gate to open it. Something is wrong with your circuit somewhere. Measure DCV at the gate of the FET and see what the conditions are when it closes and then when it opens.madbeavis said:Any idea why its muting after 30 seconds with the Gate grounded?
The PSU 0V reference should be fine. I think there's maybe something else going on.madbeavis said:Its totally possible I screwed something up here. This gives me a good starting point however, ill verify DCV at the mute header pins and maybe try a chassis ground instead of using the PSU mult.
Thanks for your help!
Chris
31cc7 said:I had a little bit more time to test my summing mixer. Unfortunately after an hour or so channels started disappearing and when I disconnected the PSU it's got a squeaky sound for a second or so. The PSU inside was extremely hot. Maybe what the power meter is showing (the 30W) is max that the PSU can give, but the mixer itself needs more?
The LM333T/LM350T are still somewhere in customs so probably I won't be able to do much with it now.
I tried to look on eBay for something I could use and only thing that seems reasonable to me would be to buy one of those racked power supplies for mixing consoles (e.g. for Soundcraft or Behringer)? Problem is that these give +/-17V - +/-18V or more. Would 2S-LA and 2-ACA-Bo work fine with e.g. +/- 18V? I read that the gar2520 I am using should be okay.
edit: I skimmed through the thread and it looks to me that slightly higher voltage should be okay.
jsteiger said:A 3-pin XLR for power is scary.
